3 members (TooMany2count, Bill Hanlon, Gray_Ghost), 32 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#1317890 07/16/2019 4:26 AM
Hi there:
I am trying to remove the engine, 235, and the 4 speed tranny out as one piece. The front clip is off but I am having hard time moving the engine using the cherry picker. The engine is almost touching the firewall and tranny mount are like c-clips over the cross member. Is there a trick as to how to remove the engine and transmission all together? Tranny cross member seems to be rivetted in therefore it would be a pain to grind all these rivets. I also prefer to remove the engine and tranny as one unit since thee is more than couple of inches of dried gunk all over every single bolt.
I appreciate the tip.
1953 GMC 150: new member
1967 Chevy C20, 4 wheel 8 lug disc, 350 engine with Fitech carb (in progress) , T5
1972 Chevy Nova, 4 door sport sedan in the making smile
1979 Chevy Camaro Z28, 5,3 Vortec and TH350, 4 wheel disc and Hydroboost; Just about becoming summer daily driver
Self #1317892 07/16/2019 4:43 AM
The only way that MIGHT work, and I'm not sure it will, would be to remove the top of the transmission with the shift tower and shift stick attached. That might allow you to lift the transmission high enough to clear the firewall crossmember. Virtually nobody does it that way- - -does the truck have an open driveline or a torque tube? An open driveline setup only requires removing the front universal joint and four bolts holding the trans to the bellhousing to drop the trans, but be aware it weighs about 120 pounds. Using an engine lift through one of the cab doors is the easy way to handle the transmission without hurting yourself or bending something. I've also used an 8 foot piece of 4X4 post between the open windows of the cab and a cable come-along to remove and install transmissions.
Self #1317895 07/16/2019 4:59 AM
Thank you Hotrod Lincoln.
It is open drive line and I have already removed the drive shaft and the shifter handle. I guess I have to separate the transmission. How about lifting the cab off a little since I plan to remove the cab at one point?
Also, how do you remove these steering column? from the box? I don't see any rag joint.
Thanks again
Self #1317904 07/16/2019 10:23 AM
Pull steering wheel, unbolt the box from the frame. Slide out column assembly. Regarding gunked up bolt head and nuts: Get a couple sacrificial sockets and grind around the perimeter for a sharp edge and tap through caked up grease. This worked for me when i had a bunch of bolts to remove and didnt want to take the time to clean each bolt for a socket to fit.
1946 GMC Project
"Back-in-the-day Restore"
Self #1318018 07/17/2019 12:09 AM
I find it pretty easy to first disconnect and drop the gearbox. Then pull the motor.
Craig
Self #1318030 07/17/2019 1:51 AM
The bellhousing mounts are to be unbolted from underneath not from the side, just one bolt per side then the entire mount slides off the rear crossmember and stays attached to the bellhousing.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Self #1318061 07/17/2019 11:45 AM
I just did what you are trying to do. I unbolted the transmission 1st, and removed it. Then from the underside of the crossmember I unbolted the 2 bell housing bolts, then the front mounts. I then disconnected the push start assembly, hoses, electricals, and it pulled out easily. I took the time to scrape away at the grease and also used simple green.
