1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2018 Posts: 34 | I purchased this '52 - 3100 with a 235 engine. From what I can tell by the numbers stamped on it the block is a '54, head is '52. Has been running ok but recently sounds like it's missing occasionally. Has always leaked oil - guessing the rear seal, sometimes I see the valve cover wet by the fire wall, and occasionally a little out of the draft tube. As soon as I start it the gauge pegs to 30lbs. Bought a oil pressure test gauge and it reads 35-38 at idle and 40-45 revving it slightly. This seems high from what I've read. Ideas?? Suggestions??
I have another "new" '54 235 I was planning on putting in this winter.
Mike
1952 -3100 with '52 235 Iowa farm truck "Cecil" | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Those pressure numbers sound normal for a good condition 54-62 235 with full oil pressure to the connecting rods. The earlier 235's (1941-53) used a different connecting rod lubricating system consisting of spray nozzles that squirt oil into dippers on the bottom of the connecting rods, and do not have pressurized oil passages in the crankshaft. Those engines typically have 0-15 PSI oil pressure at idle, and a really good one might have 20-25 pounds of oil pressure at hot engine cruise conditions. Your pressure is definitely not "too high" for the later model engine. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2018 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2018 Posts: 34 | tclederman - This is what the truck had in it when I got it - I'm not super knowledgeable about this but here are the codes ..Also, I was incorrect earlier the head is a 1953 (from my research)
Here's the #'s - 0030392F54Y - engine serial don't have the block number with me 3701887-gm7 head b2-887-066-570
Thanks - I didn't realize I could update my gauge with 0-60.
Mike
1952 -3100 with '52 235 Iowa farm truck "Cecil" | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A 1953 15 bolt head will not bolt to a 1954 18 bolt block "0030392F54Y - engine serial number (pressed into the block)" F = Flint MI engine plant 54 = 1954 Y = car 235 with RPO 313 (Powerglide 2-speed automatic transmission) This engine would have had hydraulic lifters (no truck engines came with hydraulic lifters). "don't have the block number with me 3701887-gm7 head" 3701887 = 1953 truck low-pressure 235 head b2-887-066-570 ??? where did you find that code? Find a post the head/block casting codes, and date casting codes.With the date casting codes, we can better date the engine. How many bolts/nuts/screw are used to attach the valve cover to the block? | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | In 1953, both low pressure and full pressure 235s had 18 bolt heads. Weird, but true.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Carl,
I thought that was only on the 1953 Powerglide 235 head (high pressure engine?).
But, I see in the MPB that the 3701887 1953 head was used on all 1953 235 engines (car and truck).
And (/but), there were two 235 blocks in 1953 (both different from the earlier 1952 low-pressure 235 block and the later 1954 high-pressure block).
3701481 casting code for 1953 Powerglide 235 block 3701946 casting code for 1953 non-Powerglide 235 block (car and truck)
It might seem odd, but I like being corrected on these technical matters, and, I like learning something new about Stovebolt engine history.
(I lead a sad and lonely life.)
| | | | | Joined: Aug 2018 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2018 Posts: 34 | I'm still looking for the casting code on the block but the date code is K163. I need to pull the valve cover to get the date code on the head -- it leaks so bad so I've delayed in doing this. Will do this weekend.
b2-887-066-570 ??? where did you find that code? --- It's on the head between spark plugs 2-3
The valve cover is attached with 2 acorn nuts.
Just fyi - truck vin is 21kp19244
Mike
