7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl),
117
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 56 | So, I need a new master cylindar for my 2 ton chevy . It has sat in a barn 4 several years. So when i replace it and if I find the hydrovac if it isn't any good can I do away with the hydrovac ? Are they a burger of rebuild? Or can I update with something newer?
I just finished a 1946 chevy pickup street rod now on a 1950 chevy 3100 . also a GMC 220 with duals and a 1948 chevy 2 ton | | | | | Joined: Feb 2016 Posts: 1,982 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,982 | I have a '57 two ton, I was able to rebuild the master and all six wheel cylinders. I replaced every steel and rubber line and bypassed the hydro-vac due to internal brake fluid leaks. I have no problem stopping the truck even when loaded with hay, not the heaviest load I agree but I'm happy with it as is.
