2 members (Peggy M, crenwelge), 173 guests, and 3 robots.
Topics128,077
Posts1,056,015
Members48,433
#131719 08/13/2002 1:34 AM
U
Junior Member
Junior Member
U Offline
How do I get in touch with Mor-Drop? I see lots of articles indicating their services have been used, but can't seem to track them down easily. I want to drop the nose on a 52 without grafting on a new front end.
#131720 08/13/2002 1:47 AM
Anonymous
Unregistered
Anonymous
Unregistered
A google search revealed the following . . .
Mor-Drop Axles
600 29th Avenue
Oakland, CA 94601
510-261-1888
#131721 08/13/2002 10:22 PM
U
Junior Member
Junior Member
U Offline
Thanks, Ken. Appreciate the info. Steve F.
#131722 08/16/2002 9:13 PM
Hey Guys mor drop is the right place to go....I Drove down and picked up a 4 inch drop for $400. with an exchange . The limit is a 4 nch drop and You have to shorten the tie rod about 1/2 to 3/4 of an inch as well as moving the balls(grinding them off and replacing tem on the bottom. This guy has several front axles in stock at all times and will do almost anything you need. Remember to take your spindles off if you want t keep them, you will have to get new king pins pressed in and possibly reemed out do to the kingpin hole being alittle egg shaped [ but still round] god luck. The building is right off 29 th ave off to the side of the bridge...you can't see it until your almost past it. They have a sign painted on the side of the building. Good luck and I hope this helps.
#131723 08/24/2002 8:24 PM
do they make a drop axel for a 1ton?
