0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#1316954 07/08/2019 2:41 AM
Good Evening Bolters,
My EM Brake cables are seized up and so far I have not been able to loosen them up. Any body have any ideas on what can be used to break them free in protective sheath or know a source with replacements that will work a 46 2 ton? Attached are a couple of photos of what they look like.
Kregus
Lakewood, CO
1946 2 Ton (I think)
V
VEW Offline
V Offline
I've had mixed success in freeing up brake cables, depending on how far gone they were. You do want them to slide freely though the sheathing. I've used WD 40, PB Blaster, Marvel Mystery Oil, and a combination of all three.
There are services that will make what you want - George's Cables is one I can think of.
~ Victor
1957 3100 - moved on
Riding in the Passing Lane
I have a long piece of PCV pipe with a cap on one end. I fill it with solvent & put the cable in it & let it soak for a day or 2.
George
1972 Chevy c10 Cheyenne Super
After the cables have been soaked well, I would take a foot or so in my hands and move it like I was turning the crank on a bike. Then move along the cable a short way and do it some more. This puts a lot of flex in every part of the cable very quickly and breaks each wrap of the cover loose from the inner wire. I have had good luck with this method. IF it comes free, which is a pretty good chance if it is not bulged or broken, I would then clear away the solvent, perhaps with something drying like spray brake cleaner and soak it again but in oil this time. I would crank the cable again to be sure the oil got in everywhere.
Solvent or oil will soak in from the outside of the coiled covering if it is flexed to open up spaces between the individual wraps. You will have to work out all the rust debris to get the cable to work smoothly. It can take a while.
I have cut the corner out of a small plastic bag and fed the end of the cable through the hole. A rubber band will secure the bag to the cable. Fill the bag with oil and suspend the bag end up. Work the freed cable in the housing to flush out crud and oil the whole unit.
Good luck.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Make up a tube like George suggested. Put the cables in then fill with Evaporust and screw the cap on. Let it set a couple of days. Remove the cap and empty the Evaporust. See if the cables are now free. If not the fill the tube with Kroil and put the cables back in, seal it up and leave it for a week or two. Hope it works for you.🛠
Thanks for the feedback. I have tried the tube method with WD40 but I will work it again with some of the other products you mentioned.
Kregus
Lakewood, CO
let them soak in a rust dissolver
