2 members (Stewart2, Hanks custodian), 96 guests, and 8 robots.
Topics128,014
Posts1,055,324
Members48,419
#1316889 07/07/2019 5:56 PM
Vintage Truck & Tractor
I believe this confirms I need to have the head worked on. Here are my compression readings
Cyl. Dry. Wet
1. 150 150
2. 130. 130
3. 145. 140
4. 70. 70
5. 145. 145
6. 145. 145
#2 fouls a plug , I was surprised that 4 was so low.. It is a 235 in a 1962 C20. It puts out alot of blue smoke. I adjusted the valves.
What does this say to you experts?
Current project; 1961 C20, 235 I6
Fox Offline
Check to see if a rocker arm is compromised on #4. I had a similar problem on mine and it turned out that the rocker was cracked ( it later broke in two).
Or
Perhaps you have a burnt up valve? Bent rod?
Bad ring?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I Don’t know about that. Those compression values are not unusual for a 235 with the exception of no. 4. That one is low. If you can get access to a leak down tester, you might leak no.4 and see where the loss is.
Mike
I double checked compression on all cylinders. Re checked my tappet clearances too. Also checked #4 push rods. Not broken or crooked. Unless it isbemt and cant close all.the way I am at a loss. . I guess after the head is off it's only a few dollars more to inframe the rings and rod bearings. Like I said. The real riddle is 2 fouls a plug and 4 don't and it really smokes blue.
I put it all back togethor, ran it like I stole it then did the MMO thing down the throat
Half at fast idle.then let it idle and choked it down with the other half of the bottle. . I'll let it sit overnight .
Air test all the cylinders BEFORE you remove the head. It's the only way to get a good check on the condition of the piston rings.
Ok. Don't seem like that would be hard to do. I'll give it a whirl and let you know what I get..
More than that
inframe
Never heard that term before. Looked it up and the meaning is obvious.
Keep your shirt on.
A "few dollars" is a relative term and just my manner of speaking. I know what things cost . This conversation is about diagnosing what exactly is causing the problem
What a delightful rejoinder, how kind of you to take time from your busy day to share with me your innermost thoughts.
You are welcome!
