3 members (baldeagle, Shade Baby, 1 invisible),
94
Mod | | | Forums66 Topics128,125 Posts1,056,336 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 177 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 177 | I have a 1950 Chevy 3100. Almost done getting my truck running for the first time.
I wanted yalls opinion on the factory wiper motor.
Is it worth rebuilding?
Does it work pretty good? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The vacuum wiper works quite well, if it is in good shape. You can try lubricating it, in the right place/hole. ( here is a link to a photo by Bob Adler). Or, have Ficken Wiper Service (formerly wiperman.com) | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Since I don't drive the truck THAT much in the rain, I use a vacuum wiper and like it.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jun 2011 Posts: 38 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 38 | If lubricating does not work it isn't difficult to open, clean the old grease off of everything (probably will be hardened grease), lubricate with new grease and reassemble. Generally will fix and work just fine afterwards. If not then to a rebuilder. Good luck! | | | | | Joined: Jun 2017 Posts: 177 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 177 | I followed another poster's pictures and got it apart, cleaned it up and put it back together. A quick test and it works pretty good. I'll get it installed soon.
The knob control just simply moves that little arm up and down and that's it? | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | The knob control just simply moves that little arm up and down and that's it? Not exactly. It must do so with enough torque to move the wiper blades across the wet windshield. Someone needs to create a mini-dyno for testing wiper motors.
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | What exactly do you lube it with? | | | | | Joined: Jun 2017 Posts: 177 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 177 | I think I read somewhere, transmission fluid. | | | | | Joined: Feb 2019 Posts: 4,482 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,482 | Carl52, I think Matt_Texas was referring to the on/off control knob. And yes the knob does move that lever on the top of the wiper motor. It is connected to the control knob by a small rod and two rubber grommets which hold the rod in place.
I recently sent mine out to Ficken Wiper Repair and now, mine is so strong it wipes without water on the windshield. $135 and it was returned in a week.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | If you carefully squeeze a piece of tubing, can't remember if 3/16 or 1/4 and epoxy the opposite end into dowel stock or piece of broom handle you will have a tool to remove the funny screws. Used stainless on my last one and it has held up a good while without rounding out on tight screws.
Evan
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | hmmm I wouldn't of thought trans fluid. | | | | | Joined: Jun 2017 Posts: 177 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 177 | I mentioned before that I was able to get it apart and test it. Pretty happy with it but it's been 2 years since I took it out. Looks straight forward but does anyone have any installed pictures?
There is a part... Looks kinda like two tear shaped washers with a spring holding them together. Is this the only thing keeping the linkage on the motor? | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 |
