1 members (1 invisible), 46 guests, and 2 robots.
Topics128,043
Posts1,055,610
#1315923 06/28/2019 2:18 PM
JD1
Offline
I'm new to generators.
How do I determine if my generator is working properly or if it needs to be polarized?
I installed new gauges and had the battery disconnected. If I start the truck, the ammeter is basically not moving. Shouldn't the ammeter be reading more than 0 if the generator is charging the battery?
I had to charge the battery this morning because it didn't have enough juice to start the truck.
JD
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear)
Check the terminal voltage at the battery posts with the engine at fast idle. It should be 13+ volts, minimum. Against a fully charged battery with the engine at a fast idle, the voltage should go to 14.5 or slightly more.
Yes, the generator need to be polarized. Even if it's already polarized, doing it again won't hurt anything. With the engine stopped, use a short jumper wire to connect the BAT and ARM terminals of the regulator together momentarily- - - - -half a second or so is plenty. You'll get a pretty good arc- - - -don't get a case of the vapors- - - -that's normal.
Now, with that little chore out of the way, go ahead and check the generator for voltage and current output. If you don't know how to do that, find somebody who does. Relying on the dash ammeter to give an accurate measurement of charge/discharge current is not sufficient. That meter is a WAG at best.
JD1
Offline
Thanks Jerry. How can I tell the ARM terminal? I don't remember if they are labeled (I'm at work). I can trace the battery terminal back to the ammeter/battery.
They're stamped on the terminal lugs of the regulator- - - -BAT- - - -ARM- - - -FLD. "Battery- - - -Armature- - - -Field". The armature wire is usually in the middle. The Field terminal will also have a very small-gauge wire. Battery and Armature wires are noticeably larger gauge. It's also a very good idea to run a dedicated ground wire from the regulator base to the generator housing, if one isn't there already.
JD1
Offline
Ok, I polarized the regulator. I drove the truck around for about 10 minutes with no accessories on.
I'm getting 14.5V at the battery with the motor at fast idle now.
Thanks Jerry.
It would be a good idea to invest in a "battery maintainer" if the truck doesn't get driven regularly. It's similar to a trickle charger and it prevents the battery from self-discharging over several days or weeks of inactivity. To charge a low battery properly with a generator (or even an alternator) takes several miles of driving. 30 minutes to an hour, minimum.
It would be a good idea to invest in a "battery maintainer" if the truck doesn't get driven regularly. . . .
Works like a charm - 6v/12v
