4 members (HelmutVonSchet, walter74, jay d, Rich'sToys), 95 guests, and 2 robots.
Topics128,049
Posts1,055,678
#1315442 06/23/2019 10:30 PM
Have a 37 Chev with rebuilt 57 235 installed. Have a 6 bladed fan and only have 1/4" clearance between fan and radiator. Would a newer 4 bladed fan have less pitch and then more clearance on the radiator? I think the 6 bladed came off the original 216 in the truck. Have installed the adapter plate to move the water pump to correct height and have short shaft water pump. Any help will be great. Thanks Bill
1937 GC
I expect the 6 blade fan may have more pitch.
See what an original 4 blade from the 50’s does for you.
1952 Chevrolet 3800 pickup
---All pictures---
Thanks for your input.that was my thought also. Don't want the fan to hit and damage my new radiator.
1937 GC
1/4" although not ideal can work if engine and radiator mounts are good. The fan in my 52 was about that tight, low water pump, short shaft, 4 blade fan, not good, but it was tight and did work..
---All pictures---
Any thoughts on ordering a less pitch fan from speedway or a hot rod parts supplier
1937 GC
