2 members (J Lucas, Sjm),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,534 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 5 Member | | Member Joined: Nov 2003 Posts: 5 | I have been told that the brake assembly from a '73 to '87 will "bolt on" my 66 Chevy with no modifications needed. Does anyone know if this is correct? I plan to bring it up to power brakes and steering and I want to feel sure before buying a doner truck for parts. (spindles and ball joints are my main concern.) Thanks
If at first you don't succeed, you are about average.
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i used a crossmember,a-arms,spindles,brakes,and steering linkage from an 80 c10 on my 64.10 of the crossmember bolts lined up,four needed to be slotted.you have to use the same year steering as spindles.the 80 steering will bolt on if you drill two new holes for the idler arm. | | |
