2 members (Nick in Manitou, 1 invisible),
304
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Have acquired another old Chevy and one of my vehicles has to go on a covered car port. Over the cold weather how does one keep the gas tank? Empty or full? I will use fuel stabilizer. Thanks
| | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | I always fill mine when I put them in storage for the winter.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'd say full of ethanol free gas "real gas" | | | | | Joined: Mar 2010 Posts: 58 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 58 | The tank should be full to keep moisture from condensing in the air space above the gas. | | | | | Joined: Mar 2014 Posts: 4,509 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,509 | Please keep in mind non-ethanol gas will go bad on you. From everything I've read it takes 5 to 6 months, irrespective of where you live. Ethanol gas will begin degrading in 30 days and in 3 months will border on being worthless as fuel. Add one of the products like Sta-Bil if you choose to leave gas in your tank no matter whether it contains ethanol or not. Add more than is suggested if you have a long winter. Once gas goes bad it turns orange, doesn't burn well, burns with greatly more soot and smoke, smells very bad when burning and invariably leaves a gummy varnish-like residue. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jun 2008 Posts: 325 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 325 | Full with stabilizer. Maybe it's overkill, but in the spring I drain the tank and burn the old gas in another vehicle. | | |
