5 members (cmayna, Oswald, 66flea, 2-Ton, carbking), 334 guests, and 3 robots.
Topics128,160
Posts1,057,050
Members48,463
Have acquired another old Chevy and one of my vehicles has to go on a covered car port. Over the cold weather how does one keep the gas tank? Empty or full? I will use fuel stabilizer. Thanks
I always fill mine when I put them in storage for the winter.
Brian
1955.2 3100 Truck
I'd say full of ethanol free gas "real gas"
•1952 Chevrolet 3800 pickup
---All pictures---
The tank should be full to keep moisture from condensing in the air space above the gas.
'66 C60 body, '97 C6500 chassis, '07 LBZ Duramax with Allison 1000
https://photos.app.goo.gl/cxwv1C6Ay2oxYH7u7
Moderator, Electrical Bay
Please keep in mind non-ethanol gas will go bad on you. From everything I've read it takes 5 to 6 months, irrespective of where you live. Ethanol gas will begin degrading in 30 days and in 3 months will border on being worthless as fuel. Add one of the products like Sta-Bil if you choose to leave gas in your tank no matter whether it contains ethanol or not. Add more than is suggested if you have a long winter. Once gas goes bad it turns orange, doesn't burn well, burns with greatly more soot and smoke, smells very bad when burning and invariably leaves a gummy varnish-like residue. Good luck.
~ Jon
Full with stabilizer. Maybe it's overkill, but in the spring I drain the tank and burn the old gas in another vehicle.
