2 members (VicZ, klhansen), 118 guests, and 3 robots.
Topics128,072
Posts1,055,904
Members48,429
#1315197 06/22/2019 2:04 AM
Can anyone give me more info on this thermostat that I found in a 261 long block I just bought?
It is standard size, ie 2-1/8" carries 160 opening spec. I tested it in hot water and still works great and shows no sign of deterioration.
Was this OEM? Engine was a 1962.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
That's a bellows-type thermostat. As the coolant heats up air inside the bellows expands and opens the disc valve. They work best in cooling systems with very low or no-pressure radiator caps. I'd consider a 7 lb. cap to be about maximum for that type of stat and a 4# would be better. Higher pressures tend to make them stick open or closed.
Hmm, thanks Jerry for the info, I have a four lb cap (old original radiator) can you think of a reason to not run it?
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
As long as it opens at the right temp, go for it. Eventually the bellows gets fatigue cracks and fills with coolant, so they're not as long-lasting as the pellet type. Keep an eye on the temp gauge, as one that fails in the closed position causes overheating. Of course, the wax pellet type stat can do the same thing.
Scroll down to Thermostats for more info.
The less common bellows type consists of a circular concertina of thin metal containing a volatile liquid such as alcohol or ether.
Thank you both. Interesting article.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Fulton Sylphon is a possible brand.
1952 Chevrolet 3800 pickup
---All pictures---
