1 members (baldeagle), 56 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#13145 05/09/2002 2:47 AM
Junior Member
Junior Member
I have a cracked 248 head, casting #2194819 my question will a 6107412 head work? There is a noticable difference between the two. My machine shop says the casting # 6107412 will have less compression. Will it be noticeable?
#13146 05/09/2002 5:28 AM
Yes you will notice it as a loss of power.It will then run like a chevy motor! grin
#13147 05/09/2002 12:07 PM
The 4819 head was used for 228,248 & 270 GMCs thru 1963, but the 7412 head was only used on early 228s, so they are probably right about compression. Also be careful about swapping rocker shafts, pushrods etc from one head to the other as there were some changes over the years. You may save some grief by looking for another 4819 head.
