4 members (2-Ton, Gdads51, WICruiser, TUTS 59), 61 guests, and 1 robot.
Topics128,049
Posts1,055,684
#1314510 06/16/2019 4:07 PM
Has anyone here considered using a Dodge Dakota frame and suspension under a stovebolt truck? Coilover's thread about a 6-lug Trailblazer rear end got me to thinking- - - - - most Dakotas also have 6 lugs, with a different bolt pattern than old Chevys, but some of them are also approximately the same length and width as a stovebolt. They have disc brakes, power rack & pinion steering, V6 or V8 power, overdrive, even positraction on some models- - - -and a rectangular-tube frame that could have the wheelbase altered pretty simply if necessary. I've gotten 200K+ miles from two Dakotas, a 92 and an 02, with the same 3.9 Liter V6 engine, with a minimum of maintenance.
Yes, I know, the idea of a MOPAR/Stovebolt hybrid might give some GM purists a case of the dry heaves, but I believe it might be worth considering!
I have considered it since seeing a couple done a few years back at the Spring Nationals in OKC. They were done by 2 different professional Hotrod shops. One from Texas and one from Kansas. Both done very well.
We have not done this swap but did put a new wiring harness in one done by the owner. Also put one under a 53 Ford PU. Both were a nice looking conversion when finished. The Dakota is wider, a plus, and the steering box is in a better location. A search on "AD to Dakota chassis" will give a lot of hits. I would choose it over an S10 but the market support for the S10 swap is way bigger. Also the Dakota was offered from factory with a V8 which even if going to a sbc the base unit would already be for a V8.
Evan
I happened on a shop called Code504 in Seward, Nebraska on my road trip. They specialized in S10 swap kits, but may be able to provide some info on a Dakota conversion, or may have done one. I stopped because they had some AD cabs sitting outside, so checked to see if they had any parts for sale that I could use. They didn't, but sent me to Watt's Repair and Salvage in Wymore, NE where I did find some good stuff. Code504's website is www.Code504.com. Might be worth contacting them.
grin
Now, Evan- - - - -talking about putting a SBC in a MOPAR chassis- - - - -that's really nauseating!
LOL!
LOL!
I could live with that, as long as the engine, and outside sheet metal is all Chevrolet. Nobody knows what a Dodge frame looks like.
Q
Q Offline
I have seen articles in the past on using a Dakota clip on an AD ftrame. Also a bolt on( or weld on,cant remember) kit uising Dakota parts. That might be an easy way to aproach it.
Given the option of choosing between some sort of Rube Goldberg matchup of a MOPAR front clip and a GM rear frame, and using the entire Dakota frame, I think I'd err on the side of trusting the Chrysler Corp. engineers to get it right over some hotrodder's Budweiser-fueled pipe dreams. Even the so-called "professional" chassis butchers don't have the R&D facilities of a major auto manufacturer.
My experience with small block Mopars is the 318 is very good, the 340 was my all time favorite, and the 360 does not meet the bar set so high with the bullet proof slant six. Even the old wavy valve cover 318 was a better engine than the 360 IMO. The Dakota came with the 318 so if good, run it.
Evan
Both my retired Dakotas have 3.9 liter V6's, which are basically 318's with two cylinders lopped off. They've got throttle body injection and pushrod operated valves- - - -pretty simple, basic transportation. Add an overdrive transmission that's more or less an upgraded Torqueflite, and things get even better. My 59 Burb that was originally slated for a 472 Cadillac and a Turbo 400 might have a different future coming up!
There is a guy in our car club who has a late 40s Mercury that was used as a cab mounted on a Dakota chassis, the entire running gear. It looks very nice and he said it drives nice also. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
