0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 61 Member | | Member Joined: May 2001 Posts: 61 | Yes, another steering column question!
I have a 1950 Chevy 1/2 ton truck. I want to put in it a NEW steering column with column shift. I have a rack and pinion front end. Has anyone done this before for this type vehicle? What length column works best? What did you use? What would you do differently?
Thanks! | | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I have the same year truck and suspension. I used a column out of a late 70's early 80's Oldsmobile. It's a tilt, column shift with key.
Joe
| | | | | Joined: Sep 2001 Posts: 109 Member | | Member Joined: Sep 2001 Posts: 109 | I used one out of an 84 Impala...... non tilt, column shift. Gives me the wipers and dimmer switches too!
John Kennedy 1950 Suburban street rod Pics in the Gallery....... new site up! http://home.joimail.com/~kennedyjp/
