9 members (dt235sd, Gdads51, Gib70, 3B, Phak1, 32Fordpuchoptop, 68ironhead, Jon G, 2-Ton),
79
0
Mod | | | Forums66 Topics128,049 Posts1,055,693 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I just installed a few fuses under the dash for safety. Every was fine untill two old fabric wires caught fire. I thought I had everything looking good again but now the temp guage won't work. The only movement I get is when I pull the instrument cluster out of the dash it must ground and pegs hot. Only after I disconect the ground from the battery does the needle fall back to the other side. The guage was somewhat tempermental before too. I would giggle the cluster to get it to work again. I'm getting current to the guage as well. I'd appreciate any assistance.
1958 Chevy Grumman Olson step van
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I assume it is an electrical gauge. This is the test for electrical temp gauges/senders. I believe the instruction should say "temp gauge fuse" not "gas gauge fuse"
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | The only way I can get the needle to hot is by pulling the cluster halfway out. Somehow I suppose it is grounding. How are the gauges grounded? Pardon my electrical ignorance. I guess I'll try new wire connectors. These guys look original.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Just for clarification the pink wire goes on the post towards the passenger side? When I switched wires I blew 15 amp fuse. Maybe wrong side and wrong fuse?
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 1. The power wire goes to the terminal on the cold side of gauge. The sender wire goes to the terminal on the hot side of the gauge. 2. Gauge is self grounded to the cluster case. I think there is a "slug" on a ground plate at rear of gauge that touches the can and ground is carried thru to the dash/body/motor/frame/battery connections. 3. Most of the time your problem is loss of ground or a bad sender. The gauge being the most reliable component unless you blasted it. 4. When you do the testing per my first post, report what you find. 5. There was no fuse for the temp gauge. Powered directly from ignition switch. 6. If I were you, I would stop applying power to components unless you know what you are doing.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Seems to be lack of ground. When I set the cluster back in it pegs hot even without the sender connected.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Does the temp gauge go to battery on ignition switch?
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | NO. Goes to "Key On". 1. What ignition switch do you have? 2. Do you have key start or foot start? 3. V8 or 6 cyl? 4. Stock ignition? 5. Stock motor? 6. Stock temp gauge and sender?
I am not familiar with Step Vans.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Not sure Key start 6 cyl Stock ignition 261 Stock gauge, nail head type sender, TS6
Step van is a 3400 model
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | The aftermarket temp gauge I just installed in the ‘62 was the hot (red) wire to a switched post on the fuse box. Switch on power, switch off no power.ðŸ›
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Wiring to any switched power is fine, including the ignition switch itself. In 1958, Chevy was still "short" on fuses. If there is a switched fuse that can be used, great. The limited info I can find on 58 truck wiring shows no fuse for the temp gauge. I always recommend some sort of fuse for everything when a person rewires an older truck.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I got them hooked to the right posts now. Pink wire to ignition spade not battery spade currently, but now blowing fuses. I guess this means a short somewhere? Tests suggestions earlier did not yield any results.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Tests always yield results.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Result was I did not have a good ground when testing. Sender was bad.
