1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#1313584 06/08/2019 2:05 AM
Can experts please educate me on what heaters I have here? What years are they, how do they mount, which way is up, is there a 12v replacement motor, are they rebuildable? They came as spare parts with a '49 panel truck body and are almost identical.
1951 Chevy Panel Truck
There are holes in the dash which the hose nipples go through, as well as smaller holes for the threaded studs. The forked defroster part goes up and slightly to the left.
Check the cores to make sure they don't leak. Good ones are hard to find, and new ones are expensive.
I think what you have is two :
Recirculating (only) round type heater 1947-55 1st series (round heater core) defrost to floor air control was done manually using a lever located on the heater box.
How do they mount, which way is up,
Check letters and numbers on attached photos.
Don't know about motors though. This might help
Check HERE FOR MORE INFO .
xfiles
Thank you gentlemen, that really clears it up for me. I was familiar with the fresh air style heater that attaches to the right kick panel but I'd never seen this recirculating type before.
Moderated by  ndkid275, Phak1
