1 members (Shaffer's1950),
110
7
Mod | | | Forums66 Topics128,076 Posts1,056,009 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | So after somewhat of a setback (three years ago this week we had a tornado), I am back at it, working on my Dad's 1953 3100. My original plans were a "resto-mod" with V8, Automatic, IFS, modern electronics and upholstered interior. I was going to make it for me and suit my tastes.
Now, I am thinking of going a more a "keep it mostly original with safety and reliability updates". The reason for the change is that I want my grandchildren (and my sister's grandchildren) to have the 1953 Pickup experience as close as possible to how it was when the truck was new.
My thought is, if I make it "too modern", it won't be much different than taking them for a ride in my 2016 Truck.
So I am thinking along these lines... Keep the original front suspension, rebuild it and add disc brakes Swap to a 6 cylinder that has an oil pump Keep a 4-Speed Granny transmission, but with open driveline Power brakes Keep the original rear suspension, but add disc brakes. (I already have an open driveline differential for the original rear end) Near original style wheels and tires, hubcaps Paint an original color (I'm thinking Ocean Green w/maybe Juniper Green fenders and running boards) Okay, not totally original scheme, but original colors. Ad chrome grille and chrome front bumper. Repair and keep the original rear bumper my Dad made. Bench seat with reproduction original material, add seat belts Slight upgrade to door panels and headliner, close to original appearance Add air conditioning (this is Texas after all) but do best to hide it
If you have thoughts, comments or suggestions, please share.
'53 3100 5-window '57 Mercury Monterey 2-Door Sedan Tim H
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds like a good plan. If adding AC I'd also opt for a larger engine like the 261 and not just a 235. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Lynngrove, your plans seem right on the money to me, good luck and have fun on the project. Steve 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | I like your plan. Find a good 261! I'm enjoying a fresh rebuilt 261 and Sm420 granny low 4-speed in my '53 1/2 ton. I'm non much for the 2-tone paint, but if it's your thing, go for it, I'm just glad you're not going for the chop job with a V8, etc. Sounds like you've got a nice project lined up!
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sounds like a good plan. If adding AC I'd also opt for a larger engine like the 261 and not just a 235. And a bigger radiator. It is also far easier to run an electric fan. Had the mechanical fan on the 235 in my 52, but there was only enough room for fingers between the blade and radiator. After destroying a radiator, I went electric with an aluminum radiator.
Fred 52 3600 69 C-10
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | I recall a highly modified 34 Ford roadster for sale at a car show, complete with IFS, IRS, AC, AT, PW, PDB, leather interior, high powered sound system, etc etc. I asked the owner how it drove. "Just like a new Lexus," was his reply. That poor SOB didn't realize that he was totally missing out on the old car experience. Needless to say, I didn't buy the car.
1951 Chevy Panel Truck
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If using the late 261 also use a water pump relocation plate and the fan fits just great. Electric fan might work fine but they never ever sound right in an old truck. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Looks like a good/reasonable plan, Tim
Just to get the terminology correct in your list: “Swap to a 6 cylinder that has an oil pump”
Presumably, you are referring to a high-pressure insert rod bearing 235/261 engine, as apposed to the older babbitted rod bearings 216/235 engines?
Both type of engines have an oil pump.
Good luck with proceeding with your plans.
I agree with Grigg on using a water pump relocation plate. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I wouldn't worry about having rear disc brakes, I'd stick with drum on the back. Isn't worth the cost and aggravation in my opinion. Front disc brakes will be doing most of the work stopping.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I wouldn't worry about having rear disc brakes, I'd stick with drum on the back. Isn't worth the cost and aggravation in my opinion. Front disc brakes will be doing most of the work stopping. agree with this one as well, until you get into the bigger trucks that use the rear brakes more than the front, but that is not what you are working on. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'd stick with standard/original brakes. | | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | Thank You to everyone for your comments and suggestions.
My take-aways are:
261 engine I know someone who has a 292 that I could get very reasonable, I need to look into the fit of a 261 vs 292.
Bigger Radiator From past experience, I am a firm believer in having ample cooling capacity.
Disc Front/Drum Rear Brakes I rode in and drove this truck decades ago, so I would like a bit more stopping power than the original setup. I plan on power brakes, so the Disc Front and Drum Rear may be the way to go.
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | A 292 will require modification to fit in a Thriftmaster truck, since that engine is from the 1960s-1970s trucks. The experts will be able to give you the details. The 261 is nearly a bolt-in fit. You might need to use your bellhousing from your 216 or 235. Also use the 216 water pump and adaptor plate from "Pre-68 Dave" on ebay. PM me if you want to see pictures of what mine looks like.
| | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | A 292 will require modification to fit in a Thriftmaster truck, since that engine is from the 1960s-1970s trucks. The experts will be able to give you the details. The 261 is nearly a bolt-in fit. You might need to use your bellhousing from your 216 or 235. Also use the 216 water pump and adaptor plate from "Pre-68 Dave" on ebay. PM me if you want to see pictures of what mine looks like. If I use the original bell housing with a 261, I suppose then the original flywheel/clutch setup will work also? This brings something else to mind, if all those original parts are used, I suppose I can keep the stomp starter?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Yes, the 261 (or a 235) is as easy a swap as it gets, little if anything to figure out, not even the water pump if you find a 1954 or early 55 engine. | | |
