| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All, I just received upholstery seat covers from American Classics to do my 1950 ½ ton. They supplied hog rings and not c-clips. The instructions are not very clear on how the installations works. The seat frame is not designed for hog rings from what I can tell. The sides of the bottom seat cover does not seem to be long enough to wrap under the bottom of the seat to attached c-clips. Has anyone installed the American Classic seat covers? Is this the wrong covers to use?
Thanks, Skipper
Actually the covers came from Classic Parts. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you can't use the original "barrel clips" (c-clips), most likely the covers are not long enough (Jim Carter sells those clips - they are a royal PITA to remove and to install - without small tears in the fabric). Can you compress/press the springs to allow you to attach the hog rings?
Advance-Design seat frames through at least 1955-1st series were made for use of barrel/c-clips.
On one of my sets of 1954 seats covers, I had to have a local upholsterer sew extra non-seen fabric around the perimeter of the covers. Then hog rings could easily be used. I paid a local upholsterer to install the covers (check a few small shops for quotes).
What types/layers of padding do you intend/plan to use? | | |
