| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Thought I would pass this along.I am puting new seats in my 55 2nd series.I bought a set of late model S10 seats and they fit in perfect.They have to be raised 5 to 5 1/2 inches off of the floor.They are the 60-40 seats with center armrests.Look like they were made for the truck.Hope this might be helpful to someone else out there. Dale | | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Dale-
Thanks for this info. Sorry if this is a dumb, I-don't-know-my-S-10's question, but when you say 60-40, I'm assuming there was a split bench seat with armrests. I had an S-10 with buckets and can't seem to recall the split bench option. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Yeah,it is actually a split bench seat.drivers side is wider with armrest,about 60% of the entire width.I dont know what year S10 these are from.I bought them at a swap meet.I beleive they are from the new style S10. | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | In my '57 PU, I put a full size 60/40 seat out of a '92 Chevy PU which fit perfect and didn't have to raise it. But I did have to shim a couple of the mounting pads with washers. Just another option  . | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Seon.Glad that worked out in your 57.I measured my 2001 Silverado seat and it seemed too wide for my 55. maybe the 2001 is wider than the older models,or I might have measaured wrong.Anyway it is quite a job raising these S10 seats,but they are going to work out fine.If I ever do another one maybe I will try it your way. | | |
