3 members (Rusty Heaps, Southerntruck, 1 invisible), 167 guests, and 2 robots.
Topics128,087
Posts1,055,985
Members48,430
#23575 12/20/2003 11:09 PM
I have a 1950 1 1/2 ton GMC 350 truck with a 3 speed M43 Brownie but can't find anything about this box on the net. I suspect that it doesn't belong on this truck but I'll keep it if gives me a better cruise speed. Does anyone have any info on these?
#23576 12/21/2003 1:51 PM
k10 Offline
Stricly a guess here. Wasn't a brownie used in Macks? This isn't a quad box is it? Try one of the Big Truck forums, and you should find it quickly.
#23577 12/21/2003 6:06 PM
From what I have been able to find, some were used on the big GMCs but I can't seem to find this model. Another thing that makes it tough is the tag lists several different companies and their divisions. If I remember correctly it goes:
Brown transmission co a division of ????? a division of ?????? a division of Spicer Transmission. Of course Spicer's site doesn't mention it at all.
#23578 12/21/2003 6:23 PM
k10 Offline
http://www.6066gmctrucks.org/spicer-5831-b.htm
http://www.thedieselstop.com/archiv...ollapsed&sb=5&o=&fpart=1.htm
Your looking at a Brown-Lipe transmission. I don't have anything on an "M-43". My guess is that stands for Manual trans 4 speed main, 3 speed aux. Brown-Lipe was a supplier to GMC through '42 at least. That's where my info ends. I do have a number of models listed. If you find a 3 digit or 4 digit number (numbers-no letters) post it and I might have some info for you.
#23579 12/21/2003 8:09 PM
The only thing I have found so far is a serial number: 014821
#23580 12/21/2003 9:17 PM
k10 Offline
How many speeds is it? Does it have reverse? Can you post a Side-On pic?
#23581 12/21/2003 9:34 PM
rd, If your truck is a 350 series, you've got a 2 Ton, 16000lb.gvw truck. GMC's 1 1/2 Ton truck during that era was a 300 series, 14000lb.gvw. As far as the aux. trans. is concerned, a good way to tell if it is factory, or added on later, is to look at the workmanship of the way it's installed.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#23582 12/21/2003 9:58 PM
It's a three speed with no reverse and the installation is a farmer special. The pictures of the Brownie are at
www.salemfarmgarden.com/truck pix
#23583 12/21/2003 11:09 PM
k10 Offline
Well, let's see. I've got models 6031, 6031A with direct on 2nd and OD on 3rd. Same with a 5531 model. And a model 703 used in conjunction with 3 and 4 speed units. I can't get the link to work.
#23584 12/21/2003 11:28 PM
For some reason it left off the pix part
www.salemfarmgarden.com/truckpix
#23585 12/22/2003 12:59 AM
k10 Offline
Nothing in my book is apparent that yours is listed. It looks definitely related. It's probably after '42. See if you can find a Motor book from the 50's. What do you want to do with it?
#23586 12/22/2003 1:03 AM
Thanks for looking. I am hoping to rebuild and use it. Any ideas on cleaning it? What the pictures show are after a good can of oven cleaner and a 3000 psi pressure washer using hot water. That stuff is really stuck!
#23587 12/22/2003 1:23 AM
rd, What's the "Truck", look like
Spanky Hardy
1950 GMC 250 1-Ton
#23588 12/22/2003 2:30 AM
Duals on the rear, 12' dump bed, 270 straight six and a good straight cab that is in a million pieces in my shop right now. I'll post some pictures tomorrow.
#23589 12/22/2003 7:07 PM
I posted some pictures of it this morning.
#23590 12/22/2003 8:15 PM
Good look'in 'ol truck ya have there rd. Thanks for the pictures.
Spanky Hardy
1950 GMC 250 1-Ton
#23591 12/23/2003 3:22 AM
Thanks Spanky! If I can remember the camera tomorrow I'll take some current pictures. The cab goes out for bead blasting tomorrow.
GreenGMC #1312095 05/27/2019 5:22 PM
If anyone is still looking at this. The brownie was a Watson M43 3 speed brownie. Over, under, and direct.
GreenGMC #1312118 05/27/2019 10:41 PM
W Online: Content
Dummie here. What's a brownie? Maybe a multi-speed rear end?
Why is it called a brownie?
GreenGMC #1312127 05/28/2019 12:15 AM
"Brownie" is the nick name for an auxiliary transmission made by the Brown-Lipe Company.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
GreenGMC #1312169 05/28/2019 12:28 PM
Crusing in the Passing Lane
Watson boxes were labeled such, bought or taken over by Brown-Lipe, Spicer. Not as strong as later boxes labeled 5031, 6041, etc., the 5, 6 stands for Engine torque rating in hundreds, Fine for a gasser, not diesels.
The left shift rail, rear position should be OD. Move the shift rails and count the revolutions. With the shift lever installed, OD would be right and fwd.
Ed
