| | | Forums66 Topics128,088 Posts1,056,002 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | Does anyone have a picture from the 1947-53 factory assembly manual for the 1/2 ton showing the in-cab gas tank and straps, grommets, etc | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Most likely you are referring to what is often referred-to as the 1947-1954 [Chevrolet] Truck Factory Assembly Manual? https://www.google.com/search?q=195...&sourceid=chrome-mobile&ie=UTF-8That is actually a 1954/1955-1st assembly manual. The fuel/gas tank design changed in 1954 - in particular, the fuel “pickup” in the tank, and where the fuel line exited the tank. Otherwise, other parts of the illustration should be helpful for earlier years? | | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | Here is a shot of the assembly manual page you are asking about.
'53 3100 5-window '57 Mercury Monterey 2-Door Sedan Tim H
