6 members (1955 1 Series, Still At It, Bill Hanlon, klhansen, 42465967, 1 invisible), 117 guests, and 2 robots.
Topics128,159
Posts1,056,901
Members48,458
Fox
Offline
I’m about to remove the original sprig shackles off the rear eye of the rear spring on a 51 1/2ton. My manual says that it is a threaded type. I’m not sure how I’m supposed to remove this as there is no nut or bolt head. It simply has the grease fitting and nothing on the other side. I suspect there may be a tool (or an ingenious farmer way) for doing it. I also bet that a lot of penetrating oil will be helpful.
Any tips? Help?
Thanks Bolters.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Former BMW Rider
Former BMW Rider
Fox,
I used this method as outlined by Pre '68 Dave. It worked like a charm for me.
Spring Shackle Bushing Replacement
Good luck,
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Fox
Offline
Thanks Tim, Andy.
This is helpful of course, but do you have a link/photo of how to remove the actual shackle from the spring?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
If it's like mine, there should be a bolt and nut running through the middle of the shackle 'sides'. Remove that and the sides should slide off the bushings.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Fox
Offline
Ugh. Did I overthink that one, or what?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Haha I think it’s just so surprisingly basic that you don’t expect it.
Fox
Offline
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Fox,
I hate to admit it, but I tried to hammer it, heat it, etc before I was smart enough to ask here! You are not the first of the last!
Chris
Originally Posted by ndkid275
Fox,
Chris
I just tried doing the rear spring pack pivot bolts/bushings at lunch as I know they refuse to take grease anymore. I think those will stay in a little longer, they don't want to budge at this point. Maybe if I keep trying to get grease in there and aim for potholes they'll come out in the fall with minimal persuasion.
