11 members (Tronman, Steelonsteel, Peggy M, Rusty Heaps, J Lucas, Wally / Montana, Scott, klhansen, Jon G, 2 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,206 Posts1,057,433 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13105 03/03/2002 6:56 PM | Joined: Feb 2002 Posts: 9 Member | | Member Joined: Feb 2002 Posts: 9 | i am looking for infomation and advice on aluminum timing gears and aftermarket dampers. are they worth the money? if they are worth the money who makes them and where can i get them. i have a 235 ina 53 1/2 ton. please send me any advice/ information | | |
#13106 03/04/2002 12:08 AM | Joined: Aug 2000 Posts: 8 Member | | Member Joined: Aug 2000 Posts: 8 | Your standard 235 Chevy truck engine should have an aluminium timing gear. Aluminium is stronger, fibre gears are quieter. You can adapt HD straight cut steel gears for a 4 cyl. Pontiac "Iron Duke". It depends on the end use for your engine. If it is a street engine with a mild cam and stronger valve springs the standard aliminium gear should be fine. I believe any 235/261 other than stock would benefit from an after market dampener. Both these items are for reliability. You can build your engine with the stock parts if you want, but stronger gears and an improved dampener are insurance for your "investment". What other mods are you going to do? | | |
#13107 03/07/2002 5:08 AM | Joined: Feb 2002 Posts: 9 Member | | Member Joined: Feb 2002 Posts: 9 | hey thanks for the infoo. i think i am going to go with a triple rochester carb setup with a split manifold. i am looking for a isky cam along with some elctrical upgrades. thanks again anyone nave any sources | | |
