4 members (frogfarmer, dt235sd, Frank50, 1 invisible), 267 guests, and 6 robots.
Topics128,077
Posts1,056,012
Members48,433
I am after some information to see if the engine I picked up today is a 261 or a 235. I was told it came out of a 1958 Chev truck and I am in Australia.
I have looked for the casting number on the block. All that I can find is an “M” where the casting number should be just between the distributor and engine vent.
The engine number on the pad near the distributor is GR25052 which I can’t find any reference for.
The head casting number appears to be 3836850 which from what I can find is correct for a 1658 261 head.
I can also see two “Captains Bars” just above the starter motor.
Apart from pulling the head and measuring the bore is there any way to confirm it is a 261?
Can someone please decipher the GR in the engine number?
Is it possible the block was cast in Australia and the engine block casting number is in a totally different spot?
Steve
Very Odd,
Here are the marks on my 62 261.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Was the truck originally a USA truck, a Canadian truck, or a Holden (General Motors-Holden) truck?
3B Offline
Hy reidy, a lot of Australian Chevrolets were made in Canada and shipped over, I have no idea when this practice ended, a lot of Canadian Chevrolet and GMC engines have serial numbers that begin with a G. I am surprised that you cannot find a casting number on the block they were in a few different places over the years, was the "M" you found surrounded by a circle? What size of truck is the engine from?
Didn't someone identify that "M" in the circle as the identification mark of a foundry in Canada recently? How about the oil ports on the side of the block opposite the starter? If it's got two 1/2" pipe thread plugs there for full-flow filter plumbing it's definitely a 261, but I'm not sure if that began as early as 1958.
Where is the "M" located on the block?
Is there a block casting code under/between the distributor and road draft tube?
Thanks for all of the replies so far. The "M" has a square around it and is located approximately in the center of the triangle of bolt holes that I would assume would be for the engine mounts if this was fitted to a car. It is on the Distributor.
I am not sure what size truck this came out of but I was told by the seller the truck was used to pick up milk for the Warwick dairy so I would assume a full sized truck. The block does have the outlet/inlet for oil on the non starter side and there is a large canister mounted on the manifold. The oil lines are not complete.
From what I was told the truck was a right hand drive truck so I would assume it to be Australian delivered.
The Captains bars were enough for me take the risk buying this engine and it will probably be a couple of years before I will have a chance to rebuild and use it. I am mainly trying to confirm it is a 261 so I know I can stop looking for now.
I would still be interested what is the meaning of the "GR" on the engine serial number.
Steve
"I am mainly trying to confirm it is a 261 so I know I can stop looking for now."
You have a 261.
In the USA, your codes were used on 261s in these years:
block casting code: 3769717 1958-1963 (and probably later on replacement engines)
head casting code: 3836850 1957-1963 (and probably later on replacement engines)
