Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (UnclePaddy, Oswald, Maybellene, greenie-reddy), 104 guests, and 2 robots.
Topics128,281
Posts1,058,460
Members48,490
PA OUTLAW
PA OUTLAW
1954 chevy truck 1/2 ton on the back of the master cylinder there is a banjo type bolt or fitting bolt,brass block,copper washers, a brake line attaches to centre of bolt head another line attaches to the end of the brass block dose anyone know the proper name for this assembly or were it I can buy it THANK YOU!!!!!!!! PS this truck has a hydra-matic transmission model 3100 1/2 ton THANK YOU!!!!!!!!! any vendors at spring carlisle that may have this give me a SHOUT THANKS AGAIN!!!!!!!!!!!!!!
That brass fitting (block) is different, for different years/models truck.
A truck with manual transmission has a different fitting/block than the one used on a truck with a hydra-matic transmission.
Most likely, there were different blocks on some earlier trucks?
Jim Carter & Chevs of the 40s & The Filling Station do not list any.
Maybe someone knows another vendor that has it/them.
What type of transmission on your truck?
Riding in the Passing Lane
Speedway motors has several ones.
George
1972 Chevy c10 Cheyenne Super
George,
Can you post a few (or, one) part number/s?
Awesome Grandpa
Awesome Grandpa
I just recently replaced my brake master cylinder on my 1954 3100 truck, and know exactly what part you are talking about.
I couldn't find a replacement anywhere and would like to buy one.
I bought new copper washers and re-used the old banjo bolt.
banjo bolt
