5 members (78buckshot, ShopRag, stlcardinalsguy, Ponchogl, moparguy), 79 guests, and 2 robots.
Topics128,151
Posts1,057,000
Members48,460
This end has been buried for several years. Pulled and cleaned today and confirmed my suspicions about the axle having been run without lube. I have already replaced the bearings.
[img]https://imgur.com/2fUaalI[/img]
Fred
52 3600
69 C-10
Fred T #1307556 04/18/2019 1:01 PM
No mistake of the marks left there.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Fred T #1307576 04/18/2019 3:12 PM
Possibly...
If the bearings were smoking hot the hub would have to be very hot enough to transfer heat to the axle flange. (the wheel bolted to the hub would also be really hot) If that happened I'd suspect the entire axle flange in contact with the hub would/should see the same temp and color change That is not what's shown with the outside portion of the axle flange being cool, no color. The color pattern indicates the axle shaft was the hot part and the heat didn't quite travel out to the outside of the flange.
I'd guess the colors on the axle shown are a result of the manufacturing process, tempering, and not an indication of previous severe bearing trouble.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Fred T #1307615 04/18/2019 8:29 PM
That looks kind of like induction hardening done on current production axles and bearing hubs. But I don't believe that process was used back in the day. My guess would be that the bearing surface got pretty dang hot. But I would guess that the axle surface where the bearing runs would be pretty torn up if it ran like that for very long. That color looks to be hot enough to draw the temper out of the axle. If it were mine I would get a hardness check at various spots (close to the bearing surface, for sure). If it's softened, even if not already scarred up, it isn't going to last long.
Fred T #1309932 05/07/2019 12:19 PM
Here’s a picture of another from a lightly used axle, no signs of any abuse or overheating.
The colors on the axle flange are a result of the manufacturing process.
---All pictures---
Fred T #1309938 05/07/2019 2:01 PM
Isn't that color a result of the flange being welded onto the axle during the manufacturing process? I seriously doubt that GM turned down millions of 4" diameter solid billets to make their axle shafts.
Fred T #1309941 05/07/2019 2:16 PM
They are forged, I expect they first upset the end (make it larger and or with more metal) then finish forge the flange to shape, if not done all at one wack.
The color is on top of the finished machined part, so the heat was applied after machining. I see no evidence of spin welding a flange to a shaft, and even if so it's likely the flange was finish machined after.
I still suspect the heat/color is a result of heat treating and or tempering the shaft at the very end of the whole manufacturing process.
---All pictures---
