0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I just finished putting new brake shoes and hardware on the rear of my 58 3400 3/4. The problem is that the brake shoes are not seating on the top pin. It seems the top springs should pull them in all the way. I can fit the drum over the brakes and it is tight. Could I get some advice on what's normal and what's not? Thanks
1958 Chevy Grumman Olson step van
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Check the parking brake linkage- - - -that problem is usually caused by sticky brake cables not letting the park brake hardware retract fully or incorrect assembly of the parking brake system. Jerry
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I took pics before I took everything apart. I believe I got it back together the same way. Does anyone have a diagram or pic for comparison?
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | If there is a cable from inside the cab to a Y-shaped second cable going to the rear hubs? If so, there's a threaded adjusting nut on the forward cable end. Loosen that nut several turns to be absolutely sure the linkage inside the drums isn't being held partially applied.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Ok, I will take a look at that. I know I had the e cable pretty tight when the brake problem started.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Well it didn't seem to be the cable. I noticed with the drum off the rear pad raises off the pivot the most. When I pulled the e brake and released it, the shoes did not come back into place (rear again). I'm expanding the star wheel as much as possible to seat the shoes to see if that works.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I'm going back to Jerry's idea about the e brake. Seems like a good source to revisit.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need to back off the adjustment on the Ebrake cable. Or disconnect them till you get everything else adjusted. You may have to pry back on the lever that the cable hooks to at the brake shoe. We are assuming you o-hauled or replaced the wheel cylinders. If not they may be binding. Leave the star adjusters baked off. The shoes need to seat on the anchor pin. Put the drums on then adjust the star adjuster to get a heavy drag & back off about 6 notches. Adjust the cable to get the proper feel at the emergency brake handle. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Tried all suggestions & shoes still won't seat all the way on the pin.
| | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Do you have the right shoes? It's possible a parts guy might have punched a wrong computer key somewhere! Compare them to the shoes you removed, paying particular attention to the position of holes, spring mounting points, etc. Jerry
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Parts store has old shoes-core exchange.
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I think I have 12 x 2 shoes. It looks like 3400 takes 11 x 1 3/4. Can anyone confirm?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think I have 12 x 2 shoes. It looks like 3400 takes 11 x 1 3/4. Can anyone confirm? Measure the dia meter & the wear surface on the drum. If that was the case you couldn't be that close. There should be some freeplay in the crossbar.. Do you have the shoe with the short lining in the front? Maybe you could post a photo of the brake assembly. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | Driving van for business today & did not have very good braking. Pedal almost to the floor. I guess I'll adjust the star wheel again & see what happens. I bought the 11 inch shoes, but I don't think they will work any better.
| | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | I suggest that you take the truck to a reputable brake repair shop to get to the bottom of your troubles. A '59 is modern enough that they will have no problem at all at getting you back on the road and safe. I like to do my own repairs as much as possible, but when we are talking about brakes, a guy needs to have those 100% right. Carl
