2 members (Peggy M, Ponchogl),
52
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I replaced the front shocks on my 54 3100. The shocks are Monroe and according to the vehicle selection tool on the NAPA web site they are supposed to be the correct shock for my model and year truck.
In order to install them they had to be completely compressed to fir between the two mounting points.
My question, is this right? I can see where the shock adds value when the truck front end raises up from the front axle. The shock will dampen the drop of the axle away from the frame. When I hit a bump it seems there is no value because the with the shock fully compressed in it normal position there is no room for it to compress and dampen the impact when hitting a bump.
My truck road very rough before the new shocks so the fact it hits bumps hard is nothing new but it does not seem correct?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If the shocks are fully compressed in the normal resting position of the suspension, something is wrong. If the suspension tries to dip, something will break for sure, maybe the shock mount. | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | My truck is completely stock. Not lowered any. Sounds like I either have the wrong shocks for my truck or the leaf springs have "relaxed" over time and lowered the truck on it's own. I will check out the other shocks. Thanks. | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Whenever I put new shocks on my old trucks, the front ones are pretty much neutral in action. They show some resistance in both direction, but don't go to the fully extended position like the rear shocks do. The rear shocks come with a heavy duty plastic strap which you cut after the shocks have been bolted on. The front ones never had that strap on them. Carl
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I wonder if they gave me the rear shocks instead of front shocks. The shocks had the heavy duty plastic strap compressing them. Even with that I had to struggle to force them into the bracket and get a bolt in. It is clear I need to change them.
Thanks for all the feedback.
