3 members (Stovebolt48, baldeagle, lumbersawyer), 63 guests, and 3 robots.
Topics128,014
Posts1,055,332
Members48,419
#1295876 01/23/2019 12:21 AM
Can anyone tell me the torque for the flywheel bolts, please?
engine and year?
Its a 50s GMC270. I'm replacing the 235 with it. Clutch, bell housing, and xmsn should all interchange, right?
New paint!
The clutch disc should be OK - it fits the "snout" on the SM-420
The pressure plate will be OK, if it matches the clutch diameter, and if the pressure plate will bolt to flywheel (correct number/size bolts).
The flywheel is OK if it attaches to the 270 crankshaft (correct number/size bolts).
It is my understanding that the number of flywheel-to-crank shaft bolts might be different for some GMC engines/years compared to Chevrolet crankshafts.
Someone will post a correction/clarification?
(nice looking engine)
Thanks Tim. I just want to make sure the bolts holding the flywheel on are good and tight. Don't want a steel disk flying around. smile
If the flywheel bolts are 7/16-20 like a Chevy 235, the torque should be 55-60 ft/lbs. I use a little blue Loctite on the threads as an extra precaution.
Thank you Jerry!
Crusing in the Passing Lane
Don't forget, GMC engines are about 3" longer than Chevy's. GMC move the radiator fwd in the core support.
Ed
Ed, that is an issue I am still trying to fix. I think I can squeeze the radiator in without any modifications but the front motor mounts will have to be modified. Any suggestions? Also; any recommendations on how to lift the engine? I've been using bolts in the head that hold down the rockers.
So I'm trying to install the clutch. The pressure plate has an X on it but the flywheels X was machined off. Do the Xs really need to be lined up?
No
1952 Chevrolet 3800 pickup
---All pictures---
I can send you px of a GMC radiator/core support if that would help.
Front mount also.
I also use the head bolts, carefully.
Ed
Sure! Thanks Ed.
I'll get some px tomorrow.
Ed
So I have both a Chevy radiator and a GMC radiator. Are there any differences between the two as far as performance or fitment?
The GMC is for the 270 and the Chevy came off a 235. The truck is a 48 Chevy 6100.
I have no clue of any difference other than dimensions which one can measure and pressure capacity, check original truck specs for that. If unknown, 5 psi is usually safe.
Ed
So the pressure plate and flywheel I had on my 270 was an 11" with 9 mounting holes. All of the other pressure plates I have found have 6 holes. Why the difference? Should I replace it for an 11" with only 6 holes? I mailed the pressure plate to Jim Carters as a core. They junked it and cant find a replacement. What do I do now?
I found this pressure plate on Chevs of the 40s. Does anybody know if it would work?
https://www.chevsofthe40s.com/detai...For_Clutch_1034_Heavy_Duty_150_core.html
My guess is that it will work with either a 6 bolt or a 9 bolt 10 3/4 inch clutch plate on Chevrolet flywheels..
Maybe someone else knows if the GMC bolt spacings are the same as Chevrolets'?
Redrilling and tapping matching clutch mounting bolts are not very hard to do.
Ed
I think I got a Chevy 10 3/4 plate to work. Fingers crossed.
