0 members (),
149
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 2 Junior Member | | Junior Member Joined: Dec 2001 Posts: 2 | i am wanting to swap out the old 216 thriftmaster in a 54' chevy 1/2 ton and i ran into quite a few questions the anticipated motor is a 235 from a 55' chevy 210 sedan the motor only has about 65k milesand ran very well when it was pulled about 3 years ago and replaced with a 383 stroker, i feel that the $100 price is very reasonable as it includes everything that came out to make the motor swap the irst question is the water pump I've been told that a shorter one is needed, is this an off the shelf item or do i have to order it from chevy duty, does this pump use the stock pulley and fan?? the truck still has an early 6 volt system and will be converted to 12 volt with the engine swap will the starters swap or is there a difference in the number of teath on the flywheel or flexplate will the flywheel swap from the the 216 onto the 235?? are the motor mounts the same? do i have to get a different lower radiator hose?? will the water pump have the same size inlet?? any help would be appreciated as i am a rookie to this old chevy stuff | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Try the Stovebolt tech tips http://stovebolt.com/truck/216-235.html and search "Engine & Driveline" for "235 swap." Lots of info. | | | | | Joined: May 2001 Posts: 36 Member | | Member Joined: May 2001 Posts: 36 | Are you sure the engine is a 216? Many of the 1954 truck engines I have seen are 235 high pressure. The reason I ask is that Chevy drastically dropped off the use of the 216 after 1953.
[ 12-21-2001: Message edited by: lil' johnny ] | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Unless it is a 53 registered as a 54, the 54s all have the 235 as far as I know. Does your truck have the single windshield?
54 3100 with 235 62 flatbed dump C60 with 261
