Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
8 members (Leo, greenie-reddy, Deegs53, Cosmo, Otto Skorzeny, TooMany2count, DennisM, 1 invisible), 538 guests, and 1 robot.
Topics126,781
Posts1,039,297
Members48,100
Most Online2,175
Jul 21st, 2025
I would like to replace the transmission fluid and differential fluid in my original 1954 Chevy 3100 3 speed pickup but would like some recommendations on what time of fluid to use.
For the transmission I am planning on using Traveller all mineral SAE 90 Ford tractor transmission fluid. I understand it is Ford but the manual says SAE 90 All mineral fluid and that was all I could find.
I also replaced the U-Joint in the torque tube, not sure if i should fill the ball housing with general purpose gear lube or transmission fluid?
For the rear diff I am planning on using standard 80-90 gear oil.
Thanks for the help in advance.
What would you recommend for the ball housing? Whichever I decide to put in the transmission?
same fluid/oil - that oil is "shared" by/between the transmission and u-joint housing.
Got it, thanks. Just wanted to make sure before I changed all the fluids. I appreciate the help.
Riding in the Passing Lane
The rear end grease needs to be GL-5 qualified.
1972 Chevy c10 Cheyenne Super
Yup!
I use Valvoline High Perf 80W-90 gear oil which is GL-5 qualified.
Craig
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.488s Queries: 14 (0.045s) Memory: 0.6196 MB (Peak: 0.6901 MB) Data Comp: Zlib Server Time: 2025-09-22 21:06:44 UTC
Valid HTML 5 and Valid CSS
