0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | I have a new set of tires for the truck. They are 205/75 R 15 97T passenger car radials. The "97" in the tire spec is the load index. There is a load inflation table that says the max load is 1609 lbs at 36 psi. The load table provides max loads at different pressures starting at 22 psi. At 22 psi the max load is 1069 lbs. I won't list all the entries in the table. If you are interested, see page 28 in this document: https://www.toyotires.com/media/2125/application_of_load_inflation_tables_20170203.pdfSince these are passengers tires used on a truck, the load should be reduced (according to highway regulation) by 10%. This means the max load is about 1450 lbs at 36 psi. According to the specs for a 1954 3100 pickup, the curb weight is 1855 lbs on the front and 1430 lbs on the rear. So load on each front tire is about 930 lbs It looks like I could inflate the tires to a minimum of 23 psi; table says load is 1124 lbs. 90% of 1124 = 1012 which is greater than 930. 23 (or even 24) psi seems low. Is there a common sense solution that is better than these calculations? I'm thinking 30 psi (easy to remember) and call it done.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 97T...............T= Trailer? Trailer tires have a stronger side wall. On an RV or trailer it is recommended by some that they be inflated nearer max.
A quick cursory check shows a 1994 S10 Blazer uses 205/75 R 15, has about the same curb weight and vehicle label says 32psi. You can use the "similar weight/tire size" method like that or use 32psi and sleep well.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | the "T" is the speed rating (118 mph) | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Run them as firm as your comfortable with for better mileage but watch that they wear well, adjust pressure if necessary for even wear. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I've got 205/75R15s on my '53. I run them at 35psi. I like the ride and handling at that pressure.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | The “norm” for many many years was 32psi. We would put a few more lbs in when hauling a heavy load or towing a trailer and air back down to 32psi when done. Unless your going to be using your truck as a truck, my recommendation is adjust to a level that is comfortable to you and at least the amount listed by the tire manufacturer.ðŸ›
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | When I had my Willys wagon, I had 33" swampers on it. I ran them at 25 psi on the road, anything more and it was a real stiff wide. I dropped them to 8 when wheeling, if I forgot to drop them, it sure was noticeable. I would run them home from wheeling sometimes at 8 since I didn't have an onboard compressor. If my friend was with me that had a compressor on his jeep, and we had time, I'd air them back up. | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | Yes, "T" is speed rating. I will be sure to keep it under 118 mph!
Sounds like 32 to 35 psi is good.
Thanks for the replies.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2017 Posts: 124 Shop Shark | | Shop Shark Joined: Jan 2017 Posts: 124 | The old rule of thumb I've used is 1 psi per 100 lbs vehicle weight which in your case would put you right in the 32 to 33 psi range. Then as Martin said if you are adding a lot of extra weight run it up a bit more.
38 Chevy 1/2 ton being resto-moded 65 AC Cobra replica USAF vet
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I should clarify my post. I don't keep the pressure at 35 all the time. I don't check my tire pressure as often as I should. When it drops below 30 I air up to 35 so technically anything between 30 and 35 works for me.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | LT 215/85R16 Radial - black-walled tires (and inner tubes) on my 1954 original 3100 rims/wheels (for over 14 years - about 12K miles on them).
31-32 lbs pressure is this combination's "sweet spot"
Annually, I vary/adjust the psi to obtain the the best "balance" between ease-of-steering versus smooth straight tracking on a level road (up to 65 mph).
Also, I keep the front-end parts and steering greased and properly adjusted as described in the Shop Manual (all original style parts).
14 years is a long time for tires - the tires show no checking or slits (the truck has been parked in a garage). | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I keep 45 lbs. in my front tires. It makes it easier to steer. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
