1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#1307683 04/19/2019 12:04 PM
Hi guys, I took my 48’ gmc to get a new clutch and it seems this leak started shortly after. The weird part is it seems to have gotten progressively worse. It started as a just a small drip a day to a 4 inch spot a day in about the last 2 weeks. Anyway I was wondering if there was a way for a novice mechanic as myself to fix it without taking back to the shop. Take a look at the photo and let me know what you guys think. Thanks
It looks like you have a collar at the leak that you could try to tighten. I'm not familiar with GMC since I have a Chevy but it may be worth a shot!
Ed
Hi Ed, I tried that, but no luck. If fact it didn’t even slow it down. Thanks
H Online: Content
Back the nut all the way off, and see if the seal between the nut and the pivot ball is damaged or missing. Those are still available, and I believe some of them have a diagonal cut that allows the gasket to be installed without dismantling the entire torque tube/universal joint assembly.
I think there is something wrong there. It is common for them to drip a little out the rear of the collar, but the front of it.
1951 1 Ton Completed
Jim
I have reviewed enough of your posts to realize that you have a 48 GMC 1/2-ton truck. It should have a full length torque-tube that goes from the ball and socket joint at the rear of the transmission to the rear axle - in one piece. So, I don't understand the picture you posted of the "collar". Unless it is a long wheelbase 1/2-ton. I don't have any experience with them. It looks like a slip joint in a 2-piece driveshaft. What is mounted at that crossmember?
Professional Novice
I agree with Frank50.
Jim, can you post another photo that shows us more of the drive shaft AND the rear/attachment at the transmission?
A long wheel base 1/2 ton GM of that era had a short, enclosed extension that I think had a u-joint in it.
I will see if I can find a photo on oldGMCtrucks discussion board. You should consider joining that group.
I'm more confused. Jim, the picture you posted is similar but clearly different than the pictures Tim posted. It looks like the second (rear) ball and socket, and its mounting bracket, are missing. If that's the case, I don't see how it works at all. That is, if it still has torque-tube drive.
I agree with Ed and Jerry, there has to be a seal of some kind in that threaded collar.
Some more pictures will be helpful.
Professional Novice
Start off by checking if the sm420 is over filled with gear oil. I have seen leaks out of the front like that since the rear bearing retainer is open to the collar with no seal on these models If gear oil comes out the fill plug than it has two much oil in it.If that is not the case, then remove the collar and check to see if you have the two little metal washers that sandwich the torque tube seal. If one or both were omitted on reassembly then there is your smoking gun.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
FRank the difference is because up to 1954, one is the extended bed length 1/2 ton without carrier bearing and the other is a 3/4 ton truck with carrier bearing, in both instances they have a not sealed rear bearing housing on the sm420 that needs the torque tube bell/collar type assembly
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Thanks sstock.
Jim, does any of this help you?
Professional Novice
