| | | Forums66 Topics128,205 Posts1,057,425 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 761 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 761 | I need tires for my 53 half ton. I have original wheels on it. I have located a like new set of 235/85/R16 tires at a reasonable price. I have seen on this forum, and on others that the ideal size is 215/85/R16. In my mind, the 235 tires are probably close enough to work reasonably well. I'm curious about the opinions of others, before I let my money go. Your opinions will be much appreciated. Thanks
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: May 2015 Posts: 11,186 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,186 | My guess is that the 235/85R16's will be too big for your AD. That size is the stock size for my '99 Ford F250 Superduty. They're nearly 32 inches rolling diameter, and they also mount on a 7 inch wide rim, nearly twice as wide as a stock AD 16 inch rim. The 215/85R16's fit on a 6" rim (normally) and are 30 inches in diameter.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2019 Posts: 40 | This is a Tire size and Conversion Calculator that I have found useful. https://www.americastire.com/learn/tire-size-calculator?cid=_kenshoo_clickid_&utm_source=bing&utm_medium=cpc&utm_term=tire%20calculator&utm_content=76897135440358&utm_campaign=Non%20Brand%20-%20Tires%20|%20Exact%20(Los%20Angeles)&msclkid=6592ccfa3abc157df58a91bfe0fc6a55&ef_id=W8TIKgAAAG07RAt0:20190803190251:s
| | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Things to consider. Unsprung weight, 235's are heaver than 215's hence brakes will be a little less effective and it'll ride a bit rougher. The bigger consideration is wheel offset and tie-rod clearance. With the 16" wheels I'm running 215's JUST clear the tie rods. No way 235's would work for me without different perhaps different/wider with more offset wheels and or spacers.
On the plus side the increased diameter would be a good thing on the rear since it'd effectively lower rpm making for a bit nicer highway cruiser.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I have the 235/85/R16's on my '48 3/4-ton and really like them. Check the 1st picture on my web site in my signature.
The biggest problem for the 3/4-ton, at least, is finding rims that won't touch the tie rod ends. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | I believe that the tie rod interference comes into play with rims not tires.
| | | | | Joined: Feb 2004 Posts: 29,887 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,887 | A 235 MM tread width converts to 9 1/4" of rubber on the road- - - -I hope you've been eating your Wheaties every morning and/or working out at the gym regularly. Steering that thing without power assist is going to be a real workout! Jerry
| | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Mike--I put 255-75-R16 on my 49 and they work fine--Will put the same on my 51-3100 soon, They have Bias ply Firestones now--Bill | | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Gosh, just had my 75th and didn't know I was such a powerful force on the steering wheel with my 235's. Parallel parking has been a pain in the a** no matter the tire on my '48. I like them on my 3/4-ton flatbed.
They have that firm and fully-packed look but I don't know how they would look on a 1/2-ton. Might be too big. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Mike--I put 255-75-R16 on my 49 and they work fine--Will put the same on my 51-3100 soon, They have Bias ply Firestones now--Bill They might look a little "balloony", depending on the 15"/16" wheel/rim. LT215/85R16 fit very nicely my 16" 1954 1/2 ton rims (tubeless or tube, depending on the condition of the wheel/rim). Play around with the PSI, by increasing/decreasing around 31 psi, until you find the best ease-of-steering vs squirreliness (wandering) at high speeds. Your 1953 wheels should be the same width as my 1954 wheels (standard 1949 and earlier wheels were narrower)? | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I ran 225 85R 16's on my 49 3100 for a while and they did OK. I bought 'em used in the case tubeless radials wouldn't work on my rims. They did. When I replaced them with new I went with 215 85R 16's and I like them much better. Steering is easier and the tires don't rub except when I try to take a corner too fast, otherwise IMHO 215's are a much better choice for a 1/2 ton AD with manual steering. Dave | | |
