0 members (), 66 guests, and 1 robot.
Topics128,076
Posts1,056,280
Members48,441
#1306775 04/12/2019 1:21 AM
I have the carb off my 57 235 to replace the gasket between the bowl and throttle plate and was going to use a gasket from a parts carb and noticed the throttle plate has a bore 1/8 larger then the original 235 carb so is my parts carb from a 261,it came off a truck with a manual choke so I might just rebuild that carb.
P Online: Content
In this pic you can see how close the 261 power valve vacuum port is to the throat, compared to a 235.
Do not focus on the fact that the 261 pic has the port coming out at an angle, that is just because it is a later design.
My Blog
The one I have looks to be from a 261 as its just as close,now would the bore in a 261 fuel bowl be just as large as the one in the parts carb is the same as the one that came on my 235.
P Online: Content
Bore example.
My Blog
The carb in question most likely is one of those rebuilt carbs with parts from everything,235 fuel bowl with a 261 throttle plate. It came off a 58 235 that had a rod through the block.
