| | | Forums66 Topics128,111 Posts1,056,243 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | I have a 49 3600 with a 216 all “stock”. I installed the Pertronix kit about 6 months ago. Everything was easy as it seemed and the truck runs well. I really like the stock plug wires so I installed those around the same time. Pertronix advised against using solid copper wires but it seemed fine.
Then I found Pertronix stock look wires and installed them. What a difference. I could tell the minute I started the truck the performance was better. So my question is.... Why is it better?
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 6v or 12v Pertronix unit. What part number?
If 12v, what coil and or ballast resistor? | | | | | Joined: Sep 2013 Posts: 1,362 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,362 | Don, can't answer the question I'm in just in case someone does.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | More info:
Stock 216 6 volt because that’s the stock setup. Pertronix makes a unit that fits my stock distributor. They supply the coil too.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 |
