3 members (WICruiser, 2 invisible), 142 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
#1305072 03/28/2019 11:29 PM
I have a 49 3600 with a 216 all “stock”.
I installed the Pertronix kit about 6 months ago. Everything was easy as it seemed and the truck runs well. I really like the stock plug wires so I installed those around the same time. Pertronix advised against using solid copper wires but it seemed fine.
Then I found Pertronix stock look wires and installed them. What a difference. I could tell the minute I started the truck the performance was better. So my question is.... Why is it better?
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
6v or 12v Pertronix unit.
What part number?
If 12v, what coil and or ballast resistor?
Don, can't answer the question I'm in just in case someone does.
RonR
1970 340 Duster
1964 CJ5
More info:
Stock 216 6 volt because that’s the stock setup.
Pertronix makes a unit that fits my stock distributor. They supply the coil too.
Never mind.
