8 members (Keepinthemstockm, TUTS 59, Wally / Montana, Jay R, papas52, Otto Skorzeny, JW51, Gdads51),
95
Mod | | | Forums66 Topics128,084 Posts1,056,333 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | So I think I have found a cooling fan for our 55.2 3600 truck.
It has a 350 engine with factory 4 speed trans.
A fellow bolter said he has a fan for me that is 17 1/2” wide.
My fan shroud is exactly 18” inside opening.
My question is how far into the shroud is the fan on your factory truck with a V8?
Does it sit inside the fan shroud or just at the edge?
Any help is appreciated.
Brian
1952 GMC model 473 dump truck 1951 Chevy 1500 stepside
| | | | | Joined: Feb 2004 Posts: 29,825 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,825 | The fan blade needs to be halfway inside the shroud. The center hub that the blades mount onto should be aligned with the back edge of the shroud opening. Jerry
| | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | Jerry,
Thanks so much. Thats the info i needed.
Brian
