| | | Forums66 Topics128,049 Posts1,055,629 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | A couple of days ago I connected the pilot light terminal on the 535 flasher to the pilot light in the turn signal switch. For some reason whoever installed the turn signals never connected it. The owner asked for it because he could never tell when he left the turn signals on.
The turn signals work fine. The problem is that the pilot light will only flash two times when you activate the turn signals in either direction. And it is always just 2 times.
I confirmed that the switch housing is properly grounded. I ran a separate ground just to confirm this. The results were the same. 2 flashes of the pilot light and then it stops while the turn signals continue to operate properly.
The pilot light is a #53 bulb and it is a 6 volt system.
My best guess is that due to lack of use over the years the contacts in the flasher for the pilot signal are oxidized so much they overheat and quit to pass electricity after the 2 cycles.
Ideas are appreciated!
Rusty
| | | | | Joined: Mar 2019 Posts: 24 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 24 | If you checked all the wires were connected properly, you are probably correct about the bad flasher. The third prong on the three prong flasher is only for the signals that use just one pilot light.
Reread your post, the #53 bulb is 12V. You need the 6V small base bulb.
Wayne | | | | | Joined: Mar 2019 Posts: 119 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 119 | Thanks Wayne!
I had drafted a post that I figured out the #53 was a12 volt bulb and that was the problem. Somehow I messed up posting it.
Rusty
