6 members (Tstan7, Mike Roache, Bill Hanlon, MickeyP, HandyAndy, Hotrod Lincoln), 68 guests, and 5 robots.
Topics128,022
Posts1,055,352
Members48,420
#1302839 03/13/2019 1:36 AM
I saved a long bed today from the scrap yard. Several questions.
1. The front piece (close to cab) has the one large bolt at the top (both sides). The nut is locked on there and just spins. How do I remove?
2. The very end (tailgate) looks to be welded on at bottom left & right. Was this common or? I guess it does not come apart?
I took the entire bed assembled home.
Just trying to figure it out.
Thank you in advance.
I believe the long bed was off a 1951 truck.
1950 Chevy 3100
Shaffer's1950 #1302850 03/13/2019 2:06 AM
Fox Offline
The front panel has a very long rod that runs the entire length of the top tube roll. In order to stop it from spinning, have a pal hold a wrench on one side while you remove the other side’s nut.
I’ve never heard of the factory welding the actual tailgate in. However, the stake pockets, the vertical pieces on the box sides, have been known to be be welded to the rear cross sill to keep the box square and rigid.
If I’m off base, post a picture and it will likely make more sense to us.
Good luck.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Shaffer's1950 #1302854 03/13/2019 2:48 AM
The rear cross sill was welded to the bed sides (stake pockets) on my '51 bed. Makes sense to assist the two bolts per side in keeping things aligned.
Shaffer's1950 #1303509 03/18/2019 12:50 AM
Do you mean the hinges are welded to the cross sill? I think that’s standard. Will it open and close? Maybe I misunderstood you.
Professional Novice
Shaffer's1950 #1303533 03/18/2019 4:27 AM
No, the hinges bolt on to the rear stake pocket. The cross sill is the part below the tailgate.
Shaffer's1950 #1303543 03/18/2019 11:05 AM
Sorry, I meant to ask Shaffer about the tailgate welded on at bottom left & right.
Professional Novice
Shaffer's1950 #1304071 03/21/2019 5:15 PM
Frank50,
Sorry. The very bottom rear piece. Goes driver to passenger side. It is welded on both sides. ///Not the tailgate it is already removed. The piece it mounts too. The Rear Cross Sill?
1950 Chevy 3100
