4 members (Otto Skorzeny, UtahYork, klhansen, mk72), 51 guests, and 1 robot.
Topics128,053
Posts1,055,776
#1303450 03/17/2019 5:24 PM
I have a 1938 GMC 1/2 ton long bed panel truck. I am trying to locate the truck's serial # , which I've been told is stamped on the frame somewhere. Is there somebody here that knows the location of the serial #? There is no data plate on the truck.
I know the Chevrolet truck locations, but not the GMC (they might be different).
There is no indication of a frame serial number on 1938 Chevrolet trucks.
1938 Chevrolet cars had a code stamped into right side rail behind the radiator shell.
Maybe someone has a 1938 GMC truck Maintenance Manual?
Crusing in the Passing Lane
GMC trucks have SN stamped on the R frame rail, outside, behind the front tire.
Ed
back yard wrench turner
"38 Chevy trucks serial numbers are on a plate attached to the passenger side cowl under the hood.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I've looked the frame over carefully and haven't been able to locate a number. The fenders and running boards are removed so it makes it fairly easy to inspect most of the outside of the frame rail.
I'll get back under there with a wire brush and clean off the little bit of surface rust and see if some numbers show up.
Thank you for the help.
I found it! Right frame rail in front of the front tire. The sun was shining on it from the left at just the right angle and a quick scrub with the brush and it popped right out. Much larger stamping than I anticipated.
T 145 XXX. I don't want to post the whole number, but can somebody tell me what the T 145 signifies?
I think that stands for truck, mine started with T, I.e. T-18, T-12, T-36 etc. The number (145) might be 14.5 which is a truck size number, as in T-12, etc.
Ed
Thank you Ed.
