0 members (),
62
7
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | 49 chevy 3100. looking for recommendations on a quality bellows. Mine always seem to tear at the bottom after about 3-4 months. I know Steele offers one at a premium price and I wonder if it's worth it. Thanks
Ed
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Up until a few years ago, I would say without any doubt that Steele Rubber Products were far superior to the "off shore" products. Steele is a USA company, using quality rubber, made with quality extrusion and molding machines. However, sad to say, that they now have products made overseas. They claim that they "inspect" them to be sure they meet standards. You can't "inspect" the quality of the rubber. You have to test the composition. We don't know which are not made in their USA factory. The off shore rubber will not be the same quality as other USA Steele products. Only the form, fit and function will be near the same. The rubber quality is what controls the deterioration/strength/flexibility.
While the Steele Co. bellows is twice the price, it is probably better to buy their bellows because we are not talking about a lot of money. We can always inquire and find out if a particular part is made by Steele or supplied to Steele.
No one can ever know what goes into the "rubber" at a Chinese factory. Lots of garbage for sure. Recycled, cracks in 3 months trash. Not virgin latex/polymer.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Solved! Found a GM bellows on an auction site for a reasonable price. Hopefully it will last longer than the usual suspects.
Ed
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | If "original equipment" appearance isn't an issue, I'd be tempted to adapt a bellows from a rack & pinion steering system. They're made to flex tens of thousands of times- - - -more than a lifetime of engine starts. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | What is a GM bellows? Hope you don't mean N.O.S. We must be careful with the word N.O.S. It always seems exciting to find something never used. It is exciting for parts that are not made of, or contain, plastic or rubber. I would not recommend buying plastic or rubber parts that are already 30-70 years old for our trucks. Chances are that the rubber has lost all of it's properties and will fail in short order. Parts with N.O.S. springs, gaskets, o-rings, seals and diaphragms would be on my no-no list also unless these would be rebuilt with actual new innards.
The above also applies to "used" parts of course.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Guess I will just have to see how it holds up. Thanks for all the inputs.
Ed
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I guess if George bought NOS 11 years ago, there is hope. But he didn't say if it's still not split. I have a bunch of documentation about using old rubber. Not just my opinion. I dealt a lot with rubber in my career however. I warn about NOS from time to time. Hope you have good luck on the piece.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | That’s a neat idea, Jerry. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Bartamos ,
I agree with you about 98% on old nos rubber parts .
You need to be highly selective when buying those old rubber parts .
I've only purchased what I consider to be near perfect survivor's .
I have ( 4 ) of these old old rod seals , I'm still on the first one.
The one's that I have stashed have all been massaged thoroughly with silicone rubber protective spray
and are in vacuum packed sealed bags for future use .
My truck has ( 0 ) zero made in china stuff / offshore parts .
I own a Chevrolet not a chinamobile .
George '54 3600
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | George, You really did the right thing. Oxygen is the enemy. Sun is the enemy. Any light is the enemy. Using a non petroleum based conditioner is best if you do anything. Supposedly 303 is really good. Storing cold'ish is good.
thanks for the update on the parts you got years ago. Good news.
