5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#1301719 03/04/2019 11:11 PM
Recently purchased a 1950 3100 that among other issues needs a complete brake job. Have read that a switch from Huck brakes to Bendix brakes is an improvement and have found articles on changing over the front brakes but cannot find anything regarding the rear brakes. Can Bendix brakes be adapted to a stock 1950 rearend?
BobF #1301744 03/05/2019 1:53 AM
I don't know about articles on the rears but I would imagine the complication would be the emergency brake hardware. As the owner of two vehicles with the Huck style brakes, I can't imagine why one would want to bother changing them out.
1951 1 Ton Completed
BobF #1302447 03/10/2019 6:47 AM
Bob,
I'm going to piggy back on your thread as I am upgrading my '46 Hucks to Bendix and have learned a few things about them in the course of tracking down the parts as well as understanding which parts will fit.
I was given a '51 passenger car axle. These will fit on a pickup for the fronts, but will not work for the rears. In fact the rears are an issue in themselves...read on.
To convert you need the hubs, drums, plates, shoes, cylinder, hardware for both sides. If you have a 1/2 ton pickup you will be safest upgrading from a '51-'59 1/2 ton pickup. These parts should have a 6-lug hub/drum. Passenger cars had 5-lug hubs with 5 lug drums. So, it all depends on what type of wheels you have and if it was converted over to 5-lug hubs/drums, and if that had been done you would want the hubs and drums from the passenger car also. The hubs/drums are not interchangeable, each are specific to the number of lugs. I think some of the newer drums might have holes for both lug patterns, but not 100% sure. You can't use the hubs and/or drums from truck vs. passenger car and piece them together.
Best I can tell, the plates and all the hardware will mount to either a passenger car or 1/2 ton pickup. If you have 6-lug hubs/drums, it's easiest to find a '51-'59 truck to get all the parts from. I also found a complete set from a '53 1/2 ton pickup that the owner was doing some heavy modifications on, he's going to send me the parts. The plates and parts would work, say using a passenger car plates, cylinder, shoes and hardware on your truck, but you still need the hubs and drums to match your wheels. Unfortunately you can't use your Huck drums or shoes since the size of the shoe liner is 1-3/4" x 11", and on the Bendix they are 2" x 11".
The rear is not as easy, as the Bendix rear plates are not centered like the Huck rear plates. Since you have an AD pickup, maybe it will be easier than me. I don't know the exact details yet, but you will need to modify the plates and/or mount in order to center them on the rear axle. The other option is to get a newer rear axle that has the Bendix brakes on it.
You can upgrade the fronts and run Bendix on the front with Hucks on the rear, I've been told that works fine by several people that have done that, and this is what I plan to do.
I do have a dual reservoir master cylinder, so might consider power brakes at some point, but the Bendix will be fine for the time being. Actually the Hucks would be ok, IMO, they are just a bit more difficult to adjust (2 sprockets on Hucks vs 1 sprocket on Bendix). I'm currently putting my Hucks back on my truck and when I get the parts and all of the rebuild parts I need (cylinders, shoes/liners, hardware, et al) I will convert the fronts.
While I don't know the exact modifications for the rear, I have heard that it is not too bad of a modification. You might need to cut out the center of the plate and modify it, I don't know.
Here's an article: (NOTE: there is a minor modification for the front, drilling out the lower bolts that go through the spindle and the steering arm. Per this article those need to be drilled out from 7/16" to 1/2")
https://www.chevytrucks.org/huck-to-bendix-brake-conversion/
One reason is that you can get Bendix parts from most local auto stores (so I'm told). I actually need a piston, for some reason one of my cylinders only had 1 piston when I got the truck, no wonder the fluid was dry in that reservoir... ohwell But now I'm stuck until next week if I don't make the piston as I don't think I can get a Huck 1-1/4" piston.
I don't think the emergency brake is the issue, but the plates being able to mount and be centered on the axle. I'm told the plates are quite different on the Bendix rear plates, but have not compared them up close.
I can get an old piston on ebay if I want to wait, or I can turn one on my lathe. I think I might give that a go tomorrow. Why? Because I can. wink Seriously, seems like a fun little project inside, covered from the rain. blush
BobF #1303063 03/14/2019 9:57 PM
I did the rear huck to bendix conversion on my 51, after I discovered it had a 50 coded rear axle, which had a seam split.
Just bought a new later axle housing with the correct backing plates and brake hardware from a bolter here, and swapped in the axle guts - pumpkin, shafts hubs. The axle came with good parking brake cables and they fit right up to the linkage on the frame.
NHluvstruck...
1951 3100 5-window
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
BobF #1304504 03/24/2019 10:33 PM
Thanks to everyone for taking the time to respond.
