Hello all,
My '61 Apache 10 has its orginal steering column. I've been told that it is dangerous because of its non-collapsing design that could drive itself straight into your chest during a collision. So, for safety's sake, I looked into an Ididit, only to discover that they are also non-collapsing! Considering you can't use your original steering wheel with it, I'm amazed they've even sold a single one. Does anyone know of a solution that will actually make the truck safer for the driver? I see no point in changing it if there's no benefit!
Thanks in advance,
GW
