4 members (Otto Skorzeny, WICruiser, dwreills, 78buckshot), 45 guests, and 3 robots.
Topics128,042
Posts1,055,516
Members48,424
#130274 06/05/2003 1:19 PM
Can someone please tell me or post a picture of where a Chevy small block draft tube (vent pipe)is on the engine? I think this 327 of mine is supposed to have one but I can't find where it might have been blocked off. THANKS!!!
#130275 06/05/2003 3:05 PM
Right behind the distributor should be about a 1" hole between the back of the block and the lifter gallery rear 'wall'.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#130276 06/05/2003 3:11 PM
don't have a pic rite now, Russ, but it's hard to miss if it's there - it's at the very back top, but by the 327 it was usually replaced w/ the fitting for the tubing that goes to a funky little PCV on the carb [not blocked off], so ya might not find the metal pipe that early SB's had that ran off the passanger side and pointed at the road
#130277 06/05/2003 8:18 PM
Hey, Thanks guys...Yea, I found it. That's where I thought it went. Mine is sealed off by what looks like a freeze plug.
I've just added new valve covers with breathers that I routed to the air cleaner to get rid of some of the stinky blow-by. I also found a 'cap' that seals off the oil filler tube (it has a vent tube) that I also routed to the air cleaner. Hope it works. Thanks again... wink
