7 members (Otto Skorzeny, J Lucas, klhansen, Tronman, electors, 78buckshot, 1 invisible),
106
Mod | | | Forums66 Topics128,042 Posts1,055,497 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Can someone please tell me or post a picture of where a Chevy small block draft tube (vent pipe)is on the engine? I think this 327 of mine is supposed to have one but I can't find where it might have been blocked off. THANKS!!! | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Right behind the distributor should be about a 1" hole between the back of the block and the lifter gallery rear 'wall'.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | don't have a pic rite now, Russ, but it's hard to miss if it's there - it's at the very back top, but by the 327 it was usually replaced w/ the fitting for the tubing that goes to a funky little PCV on the carb [not blocked off], so ya might not find the metal pipe that early SB's had that ran off the passanger side and pointed at the road
Bill | | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Hey, Thanks guys...Yea, I found it. That's where I thought it went. Mine is sealed off by what looks like a freeze plug. I've just added new valve covers with breathers that I routed to the air cleaner to get rid of some of the stinky blow-by. I also found a 'cap' that seals off the oil filler tube (it has a vent tube) that I also routed to the air cleaner. Hope it works. Thanks again...  | | |
