| | | Forums66 Topics128,164 Posts1,056,977 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | On the old style glass fuel bowl/filer, how high does the gas get in normal operation? I say about 3/4 full, my buddy helping me says right to the top of the glass bowl is ok. Who buys who a cup of coffee? Thanks.
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | 1952 216CID. Fuel in mine sits level with the top/edge of the wire mesh filter under the glass.
Ed
| | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | I've never seen one full in any type of vehicle.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | When I started the motor for the first time it had a two barrel 2GC, the fuel was around 1/2 or little more full. Changed to a 4bbl Carter WCFB. First thing that happened was the aluminum plugs fell out. Took Hotrod’s suggestion and drove 00 lead shot into all four holes. Now gas goes to top of bowl till it starts dripping gas. Unsure of jetting as carb is off an early ‘vette and the jet number vs size must be a closely guarded secret from Carter as I can find no reference to figure out what jets it has. I know about using drill bits. Thanks.
| | | | | Joined: Feb 2016 Posts: 1,994 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,994 | My motor is a 283 with a 2GC, fuel in the filter is solid liquid to the top. Is fuel dripping out of the filter or the carb?
