5 members (Opelika Tom, Otto Skorzeny, MikeE, Wayne67vert, TexasA&M48Truck), 62 guests, and 0 robots.
Topics128,091
Posts1,056,037
Members48,433
I’ve acquired 6 Dodge Ram 4500 10 lug 19.5 wheels . Centers from original 18” dual wheels are a perfect fit. I’ve seen a truck already running wheels done this way I’ll try to post a pic when I can find it. 225/70r19.5 tires are common as dirt and very affordable, they’re within an inch of the height of the original 700-18 tires.
Robert French MY3800FIRETRUCK
Very nice!
I've done the measurements and thought this was possible, glad to see someone finally make 19.5" wheels with original 8 hand hole centers.
You should be able to use many if not all 19.5" rims you may find, not just from a Dodge, measure the inside diameter of donor rim compared to the outside diameter of you original center. Some machine work may yet be necessary for a good fit.
Look at 8R19.5 tires, also very available and they're taller a little than the original 18" tires and still skinny, they look good and you go faster. They look best on a 6" wide rim, but also fit 6.75" rim if that's what you want to use.
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg, the dodges are the only one I know of that measure right but I’m sure there’s more. I know the 19.5 GM stepvan wheels I had on my old 1 ton and like I think you have on your GMC are too small. The 8r19.5 would be my first choice but they are just too expensive, not so much for steer tread but the only drive or mud treads available are from the top name brands and you’re talking $350 and up apiece. I know I could go with steer tread tires in the back but it’s just not the look I want. I like these: https://www.tirerecappers.com/tires/mud-terrain-tires/lt22570r19-5-retread-lug-mt/
Here we go! Pics of ones already done!
Fox Offline
That is a cool truck! How did you do the hood? Did you splice a regular 3100 hood into a big bolt hood?
How did you build the back doors?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I didn’t build the guy who did just gave me the idea for the wheels. It’s on an 07 duramax chassis. I like it too but my style is way more old school than that.
Rustbucket Ranch
Rustbucket Ranch
This is nice to know! I've been wanting to do something similar to some 17.5 singles I have off my '58.
Whats the inside diameter on those 19.5 wheels?
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
17” plus a little.
A quick how to on this new idea would be nice. Looks like a very good option. Do you need to cut out the centres? Thanks
Yes the centers will need to be removed from the 19.5 Dodge wheels on a lathe. The original centers are removed by drilling out the rivets and slitting the rim with a torch or grinder. I’ll certainly write up a how too but it’ll be awhile as I’ve got several projects in front of it and money for machine shop work is non existent at the moment.
9
9 Offline
Patiently waiting on the how to.
It looks great and nothing else looks as good on a stock truck.
55 250 8 GMC Flatbed
67 M715
69 CJ5
72 M35A2 Bobbed
75 CJ6
80 K3500 Flatbed
95 XLC2
71 C30 Flat Bed
The machine shop I talked to said it’ll cost $30-40 to get the dodge centers turned out so I guess I’ll need another 120-160 to enlarge the original centers further dodge rear end im using. Send me a few s I’ll get right on it. 🤣
Crusing in the Passing Lane
Old, noncomputer lathes are quite reasonable. Easy to do your own work with a little learning. Look around town, might find a friend or a school who would let you learn.
Ed
Moderated by  Dusty53
